Quick question...?
suprz
219
Rhode island
Just wondering what the outer diameter of Selkirk class A pipe is for a 6 inch inner flue. When they built this house i swear it was after a liquid lunch on a friday before a holiday weekend! According to my studfinder, where i want to put this stove the clearance between the studs is only 10 inches!
Oops. Hope that really isn't the case when you tear into it. It is a possibility if you're looking at a corner, though.
It will be right around 8" on th OD.
That not uncommon, there is probably something going on behind the scenes that needs that stud. Framers aren't know for putting in extra studs. You will have to head off a stud in order to get 12", or find a new location.
Well, i do know that the stud in question is part of a group of 4 side by side studs now because before there used to be a wall that ended there and now that the wall is gone the carpenters filled in the gap between 2 studs with 2 more making a group of 4 and they did that because that was a load bearing wall. So you are saying that the wall thimble has to have a total of 12 inches in between studs? Because i swear this install has been nothing but grief. I cannot put the chimney anywhere else.
What does the paperwork for the thimble say about clearances? The thimble I installed had more than 2" CTC on each side of insulation alone! If I remember correctly it took a full 15" bay, but used stainless single wall instead of double wall.
If it is through the wall, you shouldn't have any problem opening it up for the thimble. The process is no different than if you called a carpenter and had them install a window in the middle of a wall.
[Hearth.com] Quick question...?
Matt
I wish I knew the dimensions of the thimble I cannot get in touch with the installer all I know is the pipe he uses is selkirk. And the install is supposed to be done next monday....I dont see it happening that soon now
