Radiant heat question
philco56
10
06279
Hi all; I am in the process of installing in-between the floor joist radiant heat system in a new addition on the house. I would like to make my own transfer plates for a staple up system. My problem is try to find mill finished aluminum, grade 1100 or 3000 with 0 temper in coil stock not sheets. I have found that trim coil stock has the ability to be formed without spring back. The problem is it is painted and I do not know if this will have an effect on the system or not?
Any advice will be greatly appreciated
Thanks Philco56
I'm sure that any coating will be an insulating barrier but to what extent? I don't know. If you do choose trim coil I can say that the stuff I bought at Home Depot had just barely enough paint to color it.
Why don't you want plates? If you're planning on using long sections of material I can tell you that you will have some problems with expansion. They will be talking to you with each temperature change. They may even work themselves loose from the subfloor.
Reactions: heaterman
I agree the thin flashing thickness plates do not grab the tube well, and have a tendency to expand and contract causing "oil canning" noise or ticking sounds. Outdoor reset controls help limit the temperature swings somewhat.
Towards the end Wirsbo suggested nailing only one side of those thin plates so they could expand and move with less noise. Not much of a transfer product with one side hanging :)
If your load in BTU/ square foot is low consider suspended tube with UltraFin type plates.
I wasn't disparaging plates. In fact I used them on my staple up and they have served me well. I was just stating that long sections of aluminum, a material that has one of the highest coefficient of thermal expansion would not be the right choice in this application. As long as the plates are fully annealed and they are spaced away from each other when installed, they are quite silent.
Thanks Fred61. My biggest problem is finding the correct grade of aluminum that will form in my homemade jig for the plates. I plan on leaving 2-3" of space between plates for expansion. Plates will 36" long
Thanks Philco56
I personally wouldn't go longer than 16 inches on my plates. I don't have the numbers off the top of my head but 36 inches would expand a lot and probably make quite a bit of noise as well as working itself loose. I got my plates from the company below and formed them with a length of pex nailed to a 2x4 and laying the plate on another piece of wood with a slot cut in it then used a 9 pound sledge hammer to drive the tube into the slot.
I http://www.radiantcompany.com/?referrer=google&gclid=CJWw24uo2coCFc4YHwodEE0L9g
I have eight hundred feet of 4 and 8 foot Thermofin heavy aluminum plates underfloor.
I secured them every 16 inches or so on both sides of the plate with self piercing truss head screws.
About four inches of space between plates because that was easy to align with a piece of scrap tube when installing them.
Minimum water temperature is 70, max is 140, constant circulation.
They are into their third heating season, and there has not been a single noise from any of them.
The whisper quiet Grundfos Alpha pumps make more noise.
The coefficient of thermal expansion of aluminum is about 0.000013 inches per inch per °F.
Assume you have a 100 degree temperature swing.
Assume your plates are 36 inches long
0.000013 in/in/°F * 100°F * 36 in = 0.0468 inches
That's less than 1/16 inch total expansion in this scenario. Adjust the numbers for your particulars.
Tightly secure the plates with truss head screws or some other wide head fastener every eight inches and the expansion between screws works out to about 0.010 inch - about the thickness of two sheets of paper. Maybe consider using a plastic washer under the fastener head if you are real concerned about oil canning and noise.
As Mr. Rohr mentioned, if you can incorporate outdoor reset and constant pumping that will eliminate the frequent wide temperature swings and the associated expansion and contraction.
I would to thank all for the reply's. A little insight into what I am trying to accomplish. Square footage of the house is 1700. So that should be around 2400 feet of 1/2" pex 02, 1800' of aluminum transfer plates. The plates are the most expensive part of this project. So I made a jig to form my own plates. I have tried different grades of aluminum, the best to form is grade 1100 temper0 .019 thick scrounged from a fab shop. I would like to find a source that I can purchase coil stock in this grade and thickness x 6" wide, mill finish.
Thanks to all Philco56
