I've been reading a lot of the posts on radiant heating, and I've got to admit you guys are selling me on doing it instead of a forced air hydronic system, mainly due to the lower temps the radiant flooring uses. The hydronic forced air setup will require 160 or better to be effective, but the floor system only uses 100 or so, meaning my water will last a lot longer for heating the house. But, one thing I've seen time and again is the use of a mixing valve to cool the temps down so as to not melt the lines. Where does this mixing water come from, and where does it go? If you have to mix cooler water with hotter water to get, say 100 degrees into the pex loops, where do you get the cooler water from? Once it's pumped through the PEX loop, where does it go? In a standard house a mixing valve just uses cold water from the cold water line to mix water, then it comes out the faucet and does not reenter the potable water system again. But on a hydronic system, these are basically closed loop systems, no water added or removed. Since this is the case there must be a closed source of cool water in the system along with a method of cooling it. Where does this cool water come into play? If it's coming out of the faucet, so to speak, then the pex drains into the ground, I could see how it works but not the attraction to using such a water guzzling system. I hope I've explained question clearly enough. Thanks.
