Hey guys, building a new garage this spring. 28x40 3 bay with full frost walls and poured floor. I am looking to install radiant heat in the floor. I know that I will have to basically make a foam tub to pour the floor in so that I have my underslab insulation and my thermal break to the frost walls. My question is how to do the thermal break to the frost wall? I have seen some drawings of a stepped in frost wall 6 inches below the floor height so that the frost wall insulation will have the stud wall land over it and you will have a fully poured floor all the way out to the stud wall. I think this is doable but what about where the cars pull in through the bay doors, how do I insulated the floor from the frost walls there?
Assuming your insulating the walls; and ceiling to an R 32 have you compared the cost per square foot of in floor heat
at 12, 16, 18, 24, 32 and 36 inch spacing versus a number of hot water radiators on a single loop system for the three walls and hot water to air ceiling hung heaters on a second loop that would only activate when the doors open the entire system could be heated and used at a much lower temperature.
I always worry about concrete floors in garages especially if they are not scored properly or installed properly with felt expansion joints and or floor drains. The entire slab foats unless it is properly installed with expansion joints and felt or the proper amount of rebar for the entire slabs square area.
The so called "builder" that installed my fathers garage slab incorrectly and it looks like a spiderweb with all the cracks because it was not installed properly with a score slot or expansion joints.
At least with radiators the piping is exposed and you can find the leaks if you know you have them.
Another thing to consider is forced air heat in a large garage like that when comparing the cost per square foot as the registers can be placed in the ceiling and near the overhead doors if desired.
The other advantage is the registers can be closed and only a certain number of them left open by the overhead doors if desired to counteract the loss of heat as quickly as possible.
The thing is that heat is going to leave your garage the minute an overhead door is open and it will take a long time for the slab to recover.
By having new steel or surplus cast iron radiators installed the heat loss is gradual and not massive and the heat in the garage will be back up to temperature sooner as the radiators are the only thing shedding head versus the entire slab.
You could install the radiators along both walls and have more than enough heat for the garage as the radiators are about 150 BTU per square foot of area in heating area for each radiator section and many large surplus radiators are still saved rather than scrapped.
I could see heating the apron on a separate loop if there is an ice buildup in your case but not having floor heat.
