Ravelli RV80 for sale
biketony
14
48170
One year old Ravelli RV80 Pellet stove for sale. Works great and in great condition. We are selling because we wanted a stove with a larger capacity hopper. This hopper holds 33 lb's of pellets. Paid $2000.00 for this stove last fall.
Specs below
Description
The Ravelli RV80 pellet stove is in a class all its own. Modern and elegant styling with three choices for color selection paired with state of the art design and superior craftsmanship. Welcome to the new generation of pellet stoves.
Description
The Ravelli RV80 has the ability of producing up to 35,000 BTU's. Depending on climate and home efficiency, it will heat between 700 and 1,800 square feet. 33 lb. hopper capacity with a pedestal pull out ash drawer. The Ravelli RV80 has a cast iron grate, cast iron burn pot and stainless steel heat exchanger for increased fire resistance and reduced wear. Loaded with state of the art electronics and controls the RV80 is one of the most consumer friendly pellet stoves on the market. Standard programmable wall mount thermostat in addition to graphic display controls and thermostat timer.
Dimensions W x H x D (in.)
20.2 - 39.0 - 19.1
Pellet fuel consumption per hour min/max (Lbs/h) 1.50 - 4.41
Efficiency (%) > 82
Flue exit pipe (in.) 3.15
Hopper capacity (Lbs) 33
Burn Time min/max (h) 7.5 - 22.0
Installed Power (W) 290
Net Wight (Lbs) 250
Tony show contact info Located in Plymouth Michigan
Also have new exhaust pipe hookup still in the box that I would sell for $200.00
Specs below
Description
Description
20.2 - 39.0 - 19.1
Efficiency (%) > 82
Net Wight (Lbs) 250
