So my project this late summer is prettying up the wall behind the hearth . . . and now I'm looking for a bit of advice.
I pulled down about 4 feet of sheetrock to expose the studs. Put in 1/2 inch plywood with 1/4 inch cement board over that. Over this I'm putting down this porcelain tile that looks like stone.
http://www.lowes.com/pd_488152-2871...rentURL=?Ntt=silver+porcelain+tile&facetInfo=
First question: Do I need to put metal lathe over the cement board or would the plywood/cement board be enough?
Second question: The tile is relatively large . . . or at least larger than what I've used before . . . is this something I should do in stages? For example, do up to 2 feet and then wait for it to harden up?
Third and final question (for now): Would you just butter the back of the tile and apply to the wall . . . or would I want to do a scratch coat on the wall . . . and if I do that do I wait for the scratch coat to dry first.
First, thank you for being a firefighter. Your ranks are the true hero's around here.
