Ok, I suspect all of us have done this at some point or another...
Has this happened to you?
I had a smoldering little fire going awhile ago in my PE Summit, with just a couple of small splits. I put a full load in there, not even sure it was going to catch, and left to go finish some errands before bed.
In about 12-13 mins, I'm in the other room, and I smell that familiar smell of baking paint. I go running as fast as my feet can carry me into the stove room, remembering that I had loaded it up, to find the fire roaring, and the thermometer in the pipe absolutely pinned to the max. Not sure I've ever seen this. You could hear the pipe roaring... as if there was a major blaze inside the thing, and the pipes were just crackling with expansion/contraction. Plus, worse of all...the interior of the bottom pipe that connects to the top of the stove, which has these little slots in the bottom of the outside sheath, was RED HOT. I mean bright orangey/red.
Obviously, I was very concerned. I did what I probably shouldn't have, and closed off the air almost entirely, and the stove began cooling off rapidly, and the interior pipe turned back to dark.
Any likely long-lasting effects to pipes, stove, etc.?
Anything to check for? This probably lasted for about 5 mins. max.
If I encounter this again, would you solve it any differently?
Stories/solutions encouraged!
Thanks for your thoughts!
