LOL, ya, it's like I used to tell the boys at the power plants, I didn't design this XXXX'er, I'm just trying to install it and get it working.Well that's decisiveThanks for the explanation...
You remind me of my stepson, but I'm glad at least he has his own yard now for all the crap he brings home for next to nothing. Good luck with your "project stove", if you're anything like Scott that stove will run LOL!
Its like the project "homestead" in my signature that I just had to have. When we got here and stepped inside...I should have just started the car, and drove back to my moms place...but when the crowd came soon after, it was a wee bit hard to just drive away lol Might be worth the $300 ... exhaust duct on the 6041 goes for around $170. Then add the missing fans and whatever else... Are parts compatible between the 6039 and 6041?
You need a second donor stove. You start investigating this stuff and things mysteriously manifest themselves, ever notice that ?That's the issue, that darn duct! I can find both fans pretty reasonable but that duct looks like it has to come from ussc and was never a universal type part by other stove companies.
I was going to pull up the diagrams, check part numbers n all that but looks like a follow member beat me to it...
Ya that's a fact !But there is nothing like the thrill of that first fire roasting when it's cold outside and the first hours of just watching the little pellets dropping in and wondering how so little can heat so much.![]()
Well then you better scrape your parts together !I know!! I want to be apart of this, before pellets reach the price I won't be able to afford! I also like that I can burn corn, cherry pits and a few other things! I want to start experimenting! There are a few grain towers close to me, I may be able to get corn pretty cheap!
cooljjay,
I don't know how far you are willing to travel but ruger243 has a friend that has two 6039's he's willing to sell. You can pm him, ruger243 and talk with him about it. Hope that helps.
Yes. No. Maybe. Sometimes.
The auger twist ratio is different and I believe the 6041 is shorter as they have a different angle from the fuel hopper.
The fuel pot for a 6039 won't work without drilling out a hole for the ignitor that the 6039 didn't have. But, having said that I once saw a USSC stove that was identified as a 6041, name plate and all documentation that came with it. It had the square fuel chute like all other 6041's but no ignitor, and the firepot was the same as a 6039.
In some cases you might find a different make of low/high limit switch, no problem they will work, also the vacuum switch might be a different make, again not a problem. I think they just went with whatever could be sourced and met specs.
The fake firebrick will fit from one to another but you need to mod it for either a square auger hole or a round one.
Edited to add. The gear box for the auger motors are a different ratio also. I don't consider that a problem though because you can adjust the fuel feed by pounds per hour in each heat range.
Thanks for the confirmation on certain things. I know that as I helped people with 6039's locally that I was finding some differences and then the 41's were really different depending on when they came out.
I think my 6039 must have been one of the first with the 4 button control board because I got it at the Chicago Hardware Show. It was on display and got it for only $800 brand new. They don't like to have to haul things back from those shows and you can get some great deals if you have access to the show through a business. I was at least another year before I saw the 6039's being sold locally with the 4 button control panel.
That control panel is a great board, it just pisses me off that USSC doesn't explain the board better in the manual. 90% of the problems I've helped people with were taken care of by adjusting the feed or draft fan rates. To have that amount of control available and not tell people is beyond me.
They do like to be clean, no doubt. But like many other stoves I see good and bad reviews. I'm to the point where I truly believe there are just a lot of people that should not be using a pellet stove, let a lone a wood burner.
I modded a clinker pot to burn 100% corn and have burned nothing but corn for many years now and cannot even imagine how much money I've saved let alone the nice continuous heat that make the winters in WI a little more bearable.
ETA: Why on earth did USSC change the 6039 so much to the 6041 is also beyond me. I could see a couple of things but they basically half neutered the stove IMO.
