We moved to Maine a couple of years ago and have been learning how to use a wood stove since. We're thinking it's time to upgrade the stove.
I was thinking of a Blaze King Princess, but would that produce enough heat? What else might you recommend?
Our goals: We'd like to rely primarily on a stove for heat, although we also have propane. We currently have a ~20-year-old Avalon Ranier. It's in good shape and seems to work decently well but we want to tackle two issues:
I'm thinking that the Princess's higher efficiency and larger firebox would help with time-between-reloads and also, as a bonus, make it easier to use during shoulder season because we can throttle it back. But I'm not sure if it will produce enough heat. FWIW, we have space for a King but I'm just not sure how much more it would cost given we'd need to also replace the stovepipe. We're comfortable looking at premium stoves under the idea of "buy once, cry once." Other thoughts?
Appreciate any guidance!
- It doesn't put out enough heat in Dec-Feb to heat the place to 70F. In particular, when temps fall below 20F, the furnace kicks in to help it.
- It needs to be reloaded pretty frequently.
- It's not leaky
- It has only ok-to-mediocre insulation
- It has a lot of glass on one wall in particular.
- The stove is in our main room, which has a high cathedral ceiling (it spans two floors).
- We also have a kind of loft master bedroom upstairs and a couple of smaller bedrooms and a bath on the main floor.
- We cut our own firewood and have plenty available.
