We have a square chimney for a wood burning fireplace which no longer meets code. We want to keep the fireplace. It needs a new liner which will allow 0" clearance to combustibles (i.e. wood surrounding it), and which will not cut down the flue area too much.
I've been investigating cast-in-place liners. The names I've seen are Supaflu, Golden Flue, Guardian, and HeatShield with CeCure Shield. The web pages for Supaflu are "not safe", and there is no web site I can find for Golden Flue. Images I've found for both show a round liner. The Guardian system also apparently uses a round liner. A round tube will cut down the cross section too much to allow use of the open fireplace.
However, the HeatShield/CeCure system apparently can be done in a rectangular shape. Example here:
https://www.georgethechimneyguy.com/heatshield-system/sleeve-relining-system-cecure/
Info on the HeatShield/CeCure system:
https://saversystems.com/products/heatshield-cerfractory-flue-sealant
Does anyone have experience with these?
Any suggestions on finding an installer in west Michigan (the Mitten)?
Note that the fireplace is not primarily for heat, although we have a Grate Heater. It's in a mostly unheated 1901 summer cottage.
If we can figure this out there are probably a few dozen other cottages in the area which need the same solution.
Thanks.
HeatShield’s hybrid “Cerfractory” technology combines the strength of a high-fired ceramic with the heat resistance of high temperature refractory cements. HeatShield Cerfractory Flue Sealant when used with CeCure Sleeve is certified to UL 1777- Standard for Chimney Liners by Intertek. HeatShield has been tested to ASTM C199 Standard Pier Test for Refractory Mortars and is rated “Super-Duty”. It exceeds both IRC and NFPA code requirements, which specify medium-duty.
It can be used to reline masonry chimneys with the addition of the CeCure Sleeve, provided the HeatShield Cerfractory Flue Sealant mix plus the CeCure Sleeve achieve a total minimum of ½ inch lining material thickness.
Thanks.
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348130-5accbd09b847f443bde0168779c7c61c.jpg?hash=hXz1o_i-le)
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348131-59ca63e317235d78753271fcc989765a.jpg?hash=qldKSLCoBz)
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348134-9486bc066a68812ac99c70ad64934812.jpg?hash=n5TRSh5QMQ)
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348135-6f0c548f1f6236792d27ef33cfb4cfae.jpg?hash=otc4vivi7H)
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348136-b5046ef33653e8fd4271ef86ffa9eac2.jpg?hash=IzOgg6kw1s)
![[Hearth.com] Rectangular cast-in-place liner for old chimney? [Hearth.com] Rectangular cast-in-place liner for old chimney?](https://www.hearth.com/talk/data/attachments/348/348137-5e60904085c0ec109c392f836eb4c7be.jpg?hash=zFvRXHPY_t)
