We wanted to update the look of our masonry fireplace and decided to remove all the red brick that surrounded the fireplace opening. This was a single course on either side and 3 courses supported by a lentil that is 8" over the fireplace opening. I'm having trouble interpreting the code as to weather or not I need to replace the 8" of masonry over the opening instead of just keeping it open and using a stone veneer along the outside and top of the current opening.
There is concrete block for 12" on either side of the fireplace opening and continues the entire way up the wall with drywall over it past the combustible barrier defined by the code. On the inside front of the fireplace, the damper is 8" from the top of the fireplace opening, but the back is almost even with the fireplace opening if I consider vertical distance. This is my hang up with the code that states: 1001.7.1 Damper. Masonry fireplaces shall be equipped with a ferrous metal damper located at least 8 inches (203 mm) above the top of the fireplace opening. Dampers shall be installed in the fireplace or the chimney venting the fireplace, and shall be operable from the room containing the fireplace.
Then I read this section and am unsure if that is required or only if I use masonry over the fireplace that it needs to be this way.: 1001.7 Lintel and throat. Masonry over a fireplace opening shall be supported by a lintel of noncombustible material. The minimum required bearing length on each end of the fireplace opening shall be 4 inches (102 mm). The fireplace throat or damper shall be located a minimum of 8 inches (203 mm) above the lintel.
![[Hearth.com] Removed masonry over a fireplace opening must I replace that? [Hearth.com] Removed masonry over a fireplace opening must I replace that?](https://www.hearth.com/talk/data/attachments/222/222081-44c69cc48a317a91ab3e01485cf27e48.jpg?hash=JIjg7fyJsD)
But you definitely get an A for drawing!
![[Hearth.com] Removed masonry over a fireplace opening must I replace that? [Hearth.com] Removed masonry over a fireplace opening must I replace that?](https://www.hearth.com/talk/data/attachments/222/222188-73bd89813c06f670501b48ddf3fc287a.jpg?hash=cLJKSu15TM)
![[Hearth.com] Removed masonry over a fireplace opening must I replace that? [Hearth.com] Removed masonry over a fireplace opening must I replace that?](https://www.hearth.com/talk/data/attachments/222/222226-cefd48ded598a452694279698f0cc3ce.jpg?hash=e6zcCScitC)
![[Hearth.com] Removed masonry over a fireplace opening must I replace that? [Hearth.com] Removed masonry over a fireplace opening must I replace that?](https://www.hearth.com/talk/data/attachments/222/222227-ae0f3ea3db60953cb618765a87aa145a.jpg?hash=bF17nk7vxl)
![[Hearth.com] Removed masonry over a fireplace opening must I replace that? [Hearth.com] Removed masonry over a fireplace opening must I replace that?](https://www.hearth.com/talk/data/attachments/222/222228-d662abc620866285d6ed593a4b411640.jpg?hash=BxeeX7anfZ)
