Back again, with a new problem with my old Mendota wood fireplace. Two weeks ago, while cleaning out the ash buildup, I noticed a bubble in the floor of the unit. Upon cleaning, I found out that the surface of the floor refractory is starting to deteriorate. I removed the wood grate, and found that about a 5" x 6" section of the floor surface is breaking down. I used a small tack hammer to break-up the loose surface material, and ended up with a 5" x 6" oval of missing surface cement that is about 1/8 t0 1/4" deep. I tried contacting Mendota about replacement refractory panels, but their reply was that these factory panels are no longer available (not surprised). They suggested trying to repair the damaged surface with refractory cement mix, or replacing the entire floor with fire brick or pre-fab refractory panels. Since the refractory panel for the floor isn't completely flat (it has an inclined floor about 9" from the rear of the firebox, which rises at about a 20 degree incline to meet the front door opening) It seems to me that replacing the floor with firebrick is the best source of action. But, I thought that a temp fix, using refractory mortar would work until after the heating season, when I could remove the damaged panel and rebuild it with fire brick.
I ordered a tub of Rutland refractory cement mix, and after thoroughly cleaning all the loose material, I misted the area, as instructed, and troweled in the cement to fill the depression. I let the fix set for three days, and tried using a small box (ceramic) heater to help with drying the repair. The instructions mention starting a small fire and getting it up to 500 degrees for about 1 hour to finish the curing process. Since the repair is on the floor of the firebox, I wasn't sure how it would work with the ash/coal bed on top of the repair. Well, as I feared, after the burn, I cleaned the ashes out, and discovered the repair had bubbled up (probably from residual moisture in the repair boiling up and creating steam bubbles.
I am at a loss as how to cure this type of repair without removing the entire floor piece, and using the oven to complete the cure. If I have to go that route, I might as well just replace it with fire brick instead.
I guess my question is, since the refractory section is about 1" thick, would burning for the last few months of the season be a bad idea?
