I fear I'm overdoing it with these daily posts, but I've learned a lot from others and want to return the favor. So, if you're interested read on. Got up bright and early to start up the Progress. Used a top down method, worked well, almost too well, but when she started to alarm me, I was able to dial it right down. Spent several hours of regular burning, no cat, just a few splits, to get her up to temp slowly and finish off any further breaking in. Oh, yeah, and gathering up my courage. At 10 put in 2 medium splits and 15 minutes later (stove top around 350, I think) closed the bypass and dialled back the air. Gulp. She did just fine, temp on top didn't shoot up, stayed around 380. Down to coals by noon, put in 3 splits, engaged the cat again, dialed back the air to almost nothing, and she cruised along quite nicely, getting up to 430 or so. Fire lasted until 3:30. Reloaded with 3 splits again. Now for the really great part - the living room was toasty and the rest of the house was between 66 and 68 rather uniformly
! The oil furnace (set at 62) has not turned on all day! I wasn't really intending for that to happen, just hoped to get the living room nice, so I'm more or less floored. From 3 medium splits at a time. In a drafty, 2400 sq ft, non-open plan, old farmhouse. Not using fans or anything to promote air circulation. Did I mention that I'm rather pleased
A couple of things I've noticed - the stove or tee whistles all the time, should I be concerned? And, most of the day, after I engaged the cat, there was no smoke visible when I went outside, but tonite when I went out, I did see some, even though the cat was engaged. What does that mean when you see smoke with the cat engaged?
The only slight difficulty I'm encountering at this point is the lack of any marks to indicate where you are when you move the air control/draft lever at the back of the stove. I didn't happen to notice if there were any before they put the rear heat shield on. Should I just paint some on? What type paint would you use? Thanks.
Now I'm going to collapse in a puddle of spent adrenalin and sweat (have changed into a short sleeve shirt, considering shorts)
