bought a englander 28-4000 to replace the old wood add on furnace in the basement, the house is old and has a very short basement, so it would be incredibly easier to just hook it up with the same ducts for heat and return but the return went in the left side not the back. the old one just used the fan from the oil furnace next to it so you would have the filter and dont have to worry about back flow valve. the chimney came out the back so putting 90 degrees wont line up to the chimney and no room to make the chimney work.
anyone see any reason cutting it into the side and sealing the back would be a bad idea?
