dave11 said:livefreeordie said:Ok, here's another question. The po's insulated the ceiling in the basement, if I insulate the walls do I need to remove the ceiling insulation or can I leave it there?
If you have a source of heat in the basement, I'd remove the insulation, if easy to do. If no source of heat, I'd leave the ceiling insulated. If you don't use the basement much in the winter, I wouldn't bother to insulate the walls, if the ceiling above it is well insulated.
BTW--what sort of insulation is on the basement ceiling?
We use the basement to wash/dry cloths plus we have an office there but it doesn't get used much in the winter. The ceiling has R15 fiberglass bats with a paper vapor barrier facing up. There is a source of heat but it doesn't come on since the pellet stove was installed.
