Roof Brace Kit work here
Apex_predetor
27
I am going with a through-wall installation on the Gable side of my home. I have GSW/Selkirk pipe. I will need to brace the pipe once it clears the roof. Will the "Selkirk Metalbestos 6T-RBK 6-Inch Stainless Steel Roof Brace Kit" work for this application, or is it just for the other side (the name escapes me of the side the water runs off).
You can use the kit. You will have one bracket on the roof below your chimney & one bracket above it. The support rods should be adjustable to whatever length you need. The upper one will be shorter than the lower...
