I think on the bag it says it's an irritant and to use PPE when installing. If undisturbed for a few months it should be ok. It's nothing like fiberglass!Hello,
I have decided to install Roxul safe and sound in the bays of my basement ceiling for mainly sound proofing. Basement is warm and dry otherwise. Do I need to cover it up immediately, is there any health risks to not covering it for a few months?
Thanks, should I use metal straps as normal? My bays are 9", and this stuff is 3". From what I read it should work to keep noise down. Any testimonials?As long as you strap it up good you should be ok.. Its fairly heavy compared to fiberglass so may need a few extra straps to hold it into place
There are screws with large washers made for installing rockwool and stick on spikes available as well.Thanks, should I use metal straps as normal? My bays are 9", and this stuff is 3". From what I read it should work to keep noise down. Any testimonials?
Is your concern the heat or just general installation?Does anyone have any tips for installing around recessed lighting? I have the type that are insstalled to rafter faces with 4 legs.
It cuts well with a serrated bread knife or insulation knife. its actually a bit like bread in that its somewhat friable and may fall apart if roughly handled.just geneal gotcha's, like going around recessed lights, heating pipes, electrical boxes, etc. i'm doing this mainly for sound transfer. i plan on putting a thin, 1/4 or 1/8 wood panel over it installed on those steel frame hangers that separate the panels from the joists bt 1/2" to break the contact.
You can build boxes that give the necessary clearance around non-IC cans, or search “tenmat cover” at the retailer of your choice to find a pre-made rockwool dome that can be put in the attic, though you may not be talking about an attic at all.
Have you done LED retrofits in the lights?
Those fixtures are IC rated with a 15 watt max LED module.
Nice! Insulation contact air tight LEDs. When we moved into this house in Texas we had 24 non IC cans, and more than half still had incandescent bulbs. The others were CFL. Thankfully most that we could check did have rock wool covers, but we’ve retrofitted them all. It was awkward, though, because they were different types and needed different solutions.
Someone else will be better able to comment on your insulation strategy, but remember when your talking about stuffing insulation somewhere that compressing it makes it lose r-value.
Thanks. I'm not concerned with R value, 64 in basement year round with no treatment, except dehumidifier. I have an insert in the fireplace down there. But I didn't mean actuallty mean stuff, place a better word.
So, I saw this yt video where an installer put 2 Batts in the cavity, 1 up against the upper floor and then 1 at the joist face.
Is this overkill? this installer does say this is necessary to meet Canadian code for apartments.
