This is actually masonry question. I want to run a NG line into an unused firebox that had burned only wood. I've done a lot of black pipe work, have all the tools etc. Question is the best way to run it. There is a small ash dump at the back of the firebox, it goes down to an ash pit in the basement, though they are not in line with each other, the cleanout door is offset about one foot from the firebox ash door.
A black pipe gas line was installed originally as a fire starter, it is still there but has been cut off in the basement. It runs along the basement ceiling, up across the top of the pedestal that sits in front of the hearth (beneath a marble slab), then below the firebrick on the floor of the firebox, then turns and comes up into the firebox. The end there was crushed at some point and is unusable.
So there are two options. 1) Drill through the wall of the ash dump in the basement and run CSST up into the firebox. This seems to be the standard way, but the problem is that it looks like there are at least two, and maybe three brick courses in that part of the chimney. I have a two inch diamond core bit I was going to use, but it won't get through more than one course of brick, and I certainly can't drill from the other side. To run through the cleanout door itself wouldn't be good since it is only two feet off the floor.
2) Break out the necessary bricks on the floor of the firebox, and run black pipe in similar to the way it was done originally, then replace the bricks. I believe I'd need to metal-sleeve the pipe, but there certainly wasn't a sleeve originally. I'm less enthusiastic about this because I haven't done much brick work, but maybe this is a chance to learn.
Appreciate any advice.
