I've been burning my Napoleon 1400 for a bit over a month now, and I feel I have the general hang of it, and am happy with the stove.  What I've been noticing is that it's running a bit cooler than I would like.  When I refuel the stove, I leave it wide open until it gets above 500*, sometimes a bit higher if it's cold outside.  My instinct has been to close off the primary air, in stages, until it's completely closed, or as far as the control will actually close it.  I've noticed that the stovetop temp will cool down toward 400 when I do this, which is a bit cooler than the 500 - 600 the manual reccommends.   I was always under the impression that once the primary air was closed down, the internal temp of the stove would actually increase, thus increasing the stovetop temp as well.  That has not been the case.
So, I then noticed in the manual that it reccommends that the air be set at "medium-low" to maintain temps. Does this classify as a 'D'oh!' moment for me? Should I not be so quick to shut the air all the way down?
I have noticed that if the stove gets up over 600 and then I choke it back, it loses a bit of altitude, but then cruises at about 550.
I'm going to try leaving the primary open a bit this evening and see what it does.
Comments/advice always welcome! ;-)
		 hh:
hh:
