Saw recommendations - 24 inch Bar and Alaskan Mill capable
Jambx
75
Southern Connecticut
I hope all had a nice safe holiday.
You guys have seen me post the “should I get a MS361 to replace my MS270 that I bought new a few years ago. Well the saga continues but now I am off in another direction (and no I never did get a 361).
To date I have gone thought maybe 20 cords with the 270 - the biggest tree bucked was a 38 inch red oak (which had to ram it with the tractor bucket to break off the pieces since my 270 only has a 18 inch bar - took a while but it worked). I am now getting wood delivered in log length and while most are easily manageable with the 270 I do wish for a larger bar for those bigger logs. I decided to stay with the 270 because I am a small guy and the weight to me is perfect for my go to saw 80% of the time and it so friggin smooth. I just didn’t see a huge return in performance if I was to replace it with a used 361.
So, here is where I am - my 270 cuts like butter for rounds in the order of 12 - 15 inch however it does struggle for the 20+ ones - initially this was where I felt I should look into getting the 361 with a 20 inch bar (and sell the 270) but now I am thinking augmenting the 270 with a big boy (like a 461 with 25 inch bar on it). I did consider the 660 but I have read these are quite heavy and thirsty) for your average homeowner / wood processor.
One other reason I was thinking of going with a larger more powerful saw is that I recently had some nice black walnut and was thinking of making some slabs out of it with a (not yet purchased) Alaskan Mill - the 461 may come in handy for those times.
Is my direction sound?...is the 461 a nice “big boy saw” for the big boy logs?...will a 461 run a Alaskan Mill for the “odd times I want to use it”…
Any comments are greatly appreciated and as always thanks in advance!
Only recommendation is, don't just look at Stihl. All of the major manufacturers have saws that will run a 24" bar and work adequately on an Alaskan Mill.
I would be leaning heavily toward a BIG powerhead - a 461 will buck with a 24" bar just fine, but is almost underpowered for milling. If only used occasionally, it will work but slowly.
EDIT: I should say that my experience is limited to a Logosol M7, and I used a Stihl 066 w/ 25" bar for milling. It was never very fast, but it was smooth and accurate.
Reactions: duramaxman05
Your best best will be a 90cc saw for milling, you will regret getting anything smaller. A husky 390 or 395 cost about the same as a 461. Check Ashokan turf and timber near Kingston New York, he is also Spike60 on Arboristsite.com, he will give you a good deal.
Spike 60 will treat your right.
I got my 461 this spring, and it has all of the power promised. If you would keep your 270, I think they would compliment each other nicely. I have considered milling a bit myself, and I think it would do just fine (taking my time of course, and understanding I don't have the capacity of a woodmizer..). But what csm does? I have a 20" and 28" bar for the 461. The 28 likes a half or full skip to stay fast, but it hasn't let me down. Let me know if you have any other questions about the saw, I know it can be a headache to find 'the one'-
