We purchased a house with water baseboard fueled by a new oil furnace (seller installed the new furnace). I am not a fan of oil and current prices only makes that worse. They have a propane fireplace insert and honesty the heat output is not worth the price of propane. We have always had wood stoves and are making plans to buy one however I don’t think installing into the current chimney makes a lot of sense. The chimney is fine and was inspected prior to house purchase but it’s located at one end of the house where there is a cathedral ceiling to the open upstairs landing. Plus the brick chimney is on the exterior and I have always had the most success with stoves with the chimney in the house space the majority with a few feet above the roof on the outside (best draft). So thinking of closing up the chimney and putting the stove in the center of the house, through first floor ceiling and then into the open landing and eventually out through the roof. The only negative is having a black pipe off to the side in the open landing won’t look great but will put off heat. Otherwise I could build a walled-in compartment up to the ceiling but that would mean all double-wall insulated that is not cheap.
Here is a shot of the current setup. Thoughts?
![[Hearth.com] Sealing off Fireplace and Installing a Centralized Woodstove [Hearth.com] Sealing off Fireplace and Installing a Centralized Woodstove](https://www.hearth.com/talk/data/attachments/305/305932-22d4285577b4f4a289864387c69ffee4.jpg?hash=yflg0iH6qj)
