Season 15 with the E100 Wood Gun begins.
Gasifier
3,218
St. Lawrence River Valley, N.Y.
Tonight I will begin burning for the firewood heating season. The oil boiler has started to turn on too often for my liking.
The other day I installed a new fan motor, new fan ceramic heat shield, and fan assembly gasket. The original motor was still running, but was making some noise and it is time to do some maintenance work to it. The new motor is very quiet. A little more cleaning of inside of boiler tonight and I will slowly bring it up to temperature with some White Ash.
  • [Hearth.com] Season 15 with the E100 Wood Gun begins.
Motor probably just needs bearings. Fairly simple to do with a puller and can use a toaster oven to heat bearings up to get them on the shaft
Yup, a good motor will last through several sets of bearings, if taken care of otherwise, and not left go "too long" on the old bearings.
And yes to the toaster oven! I keep one on the shelf in the shop, just for bearings!
Also have an old electric stove/oven out there to heat up larger plastic parts, for customizing...PVC becomes very "cooperative" at about 220-240* ::-)
Yup.
The old, original motor will now become the backup. I bought the new motor a few years ago, when I had some extra cash, and put it on the shelf in the boiler room. Replaced a few electrical parts in the original at that time and kept using it.
Used the small puller to get the fan off the shaft of the original motor.
Time to move the cold season BTUs under some cover……
Reactions: Burnin Since 1989
Since we do a lot of bearing replacements on large motors in commercial/industrial hvac world they’ve introduced induction bearing heaters. Although not cheap we have a few at work now and they are awesome has a magnetic temp sensor to place on the bearing you enter what temp you want the bearing to get to and it’s there in about 5 minutes or so depending on bearing size. Really awesome and takes away the chance on the entire bearing not being up to temp and not getting on the shaft all the way.
Reactions: brenndatomu
We have the induction heater, but not that temp sensor...nice!
