On a new insert why would only 1 out of 3 secondary's only work ? The one in the far back of the stove is the one that works.
Let's start with this question ,Depends on how hot the firebox is and the intensity of off-gassing from the wood. If the air for the secondary manifold is fed from the rear the back tube may fire first. Is this with a full or partial load of wood in the stove?
When should the secondary's kick in ? After a full load became a bed of coals ? Please tell me ?
On a cold day, with good kindling and properly seasoned wood, you should be able to have secondaries burning within 15-20 minutes of lighting a cold stove, and lasting for 2-4 hours.Let's start with this question ,
I think I know what you are trying to say, but it could be misunderstood as saying that getting secondary flames is a bad thing. For me the only time I'd look for a full compliment of jets at the tubes would be coming into a cold house on single digit days, at any other time, I want some lazy dancing flames above the logs, usually as little as possible in order to maintain a steady heat for as long as possible.Time to say it for the first time this season: If I have a stove full of "secondaries", I screwed up. If you have a five or six hundred stove top temp and no smoke coming out of the chimney, rest. Ya dun good.
Gas jets blowing out of the secondary combustion tubes are a parlor trick.
I want as little as possible. I leave the space the stove maker intended between the load and the baffle and the burn takes place there. Not up at the baffle. This stuffing it to roof and setting off the gas show up top torching the top of the load is just wasting btus up the stack.
Burned both ways a bunch of times to find out. And the burn times and temps are the same. The difference is wood consumption.
If I'm recalling correctly, you used to have the same stove as me? So what's the 'space the stove maker internded' for a Jotul F3 CB? secondary's I thought were just to reburn the unburnt smoke? right
Not every insert & stove can have a temperature gauge ! Sometimes on these stoves there's no room for it. So then it makes it a guessing gameI the stove is up to temp, and there is only heat coming out the chimney, but no secondary flames, I wouldn't worry, secondary's I thought were just to reburn the unburnt smoke? right
No guessing needed if its daylight, if you can see any smoke from the chimney, you are not up to temperature. I'd love to do a double camera time-lapse of my temperature and chimney smoke sometime. The sharp drop-off in smoke somewhere between 380F and 420F is dramatic.So then it makes it a guessing game
Yeah. Although the stove top temp at which this happens will vary a lot (mine will do it at less than 200), it can be like turning off a switch sometimes.The sharp drop-off in smoke somewhere between 380F and 420F is dramatic.
