My stove sits next to a very flat-U shaped wall of solid masonry. In the encapsulated crawlspace, it is supported by a huge cinderblock pier, roughly 3x7ft (the "sarcophagus", the builder cleverly dubbed it)
Unsurprisingly, the masonry absorbs quite a bit of heat. When I walk out from the bedroom in the morning, thru the hallway behind it, I can feel the heat even before I turn the corner into the living room. It's really nice.
I'm wondering if it'd be more energy efficient to insulate the big pier. I imagine a good bit of heat is radiated from the pier into the crawlspace. The crawlspace typically remains in the 60s even in wintertime. So it can't be that much energy. I'm sure the crawlspace would be a bit cooler, but I doubt there's any chance it'd get cold enough to freeze pipes. Might also make the floors cooler (the insulation in the floor joists was removed when they encapsulated the crawlspace). Anyhow, I'm not quite sure how to think about the situation.
I guess I could see what the temperature of the sarcophagus is), and then use the Stefan-Boltzman law to figure out how much heat is actually going into the crawlspace.
