I live in Central Texas so I don't see below freezing very often. I'm looking for a compact wood stove that can add some heat to the house as a supplement and provide backup heat during an outage. My house is 1600 square feet but I'm not looking to heat the whole thing. I'd be happy if my wood stove can warm the living area which is open concept living/kitchen/dining so about 600 square feet or so. I can close off doors that go to this main area. My house is overall pretty tight and i have to have a path around furniture for my son's wheelchair so space is really a challenge. My current hope is in a corner as tight as possible. The Aspen and the Squirrel (1440 convection) will tuck in tight. After thorough research, reading, etc., I've narrowed it down to two units that seem workable:
VC Aspen - I like the North South arrangement so bigger logs. I like the system controlling the burn rate so there's very little for me to do. I assume it will maintain a heat level that will reduce creosote and other buildup. I also like that it is long so there is a large burner space in the front. I don't like the smaller window as there's less fire to see.
The second stove I really like is the Morso Squirrel Side 1440. It is convection vs. radiant and has very tight spacing also. (much better than the 1410). I like that it has a larger window so you can see more fire. I also like that I could turn down the air flow a bit and maybe stretch out the fire but then too cold and creosote... It also would have a smaller cooking surface as it is square. Further, the square shape means 12" max logs so a lot of cutting.
From the reviews I've read of both, it seems like the Aspen lasts longer than the squirrel.
Are there any other stoves I should be looking at that allow for really tight spacing from the corners and will burn longer than either of these?
Thanks in advance!
Thanks in advance!
