Smart thermostat Sinopé - Low voltage (24 Vac)
Zarlator
16
Quebec
Does anyone have any idea if we could do something with this kind of t-stat with our pellet stove?
Do we need a relay and special wiring ?
Is there any way to, not only control the temp, but remotely start/stop the stove ?
[Hearth.com] Smart thermostat Sinopé - Low voltage (24 Vac)
(broken link removed to https://www.sinopetech.com/en/boutique/products/neviweb-en/low-voltage-thermostat-24-vac-web-programmable/)
Been doing a lot of reading but always need a good lecture ^^
Thanks
What stove do you have?
It can control the temp in your area by hi-low setting only. Englanders dont have the capability of on-off mode. So you can have the stove run on low till thermostat calls for heat and it will ramp up to satisfy the tstat.
Reactions: Zarlator
Well, kind of frustrating. But it's a physical button so there are wires acting as a switch. Still looking for a existing solution though :)
