NH_Wood said:
pen said:
Perhaps that large chimney that your stove goes into is not drafting strong enough when the burn goes into later stages and that is why you are lacking air?
As BB mentioned, I'd give it a touch more air.
My stove did this a lot before I lined the chimney.
Now, very seldom and usually only when I turn the air down just a bit too far after having a very large load of wood.
pen
Do you think the stove would draft less a few hours into the burn? I figured the draft would be as good as it gets at that point - let me know why the draft might be low at this point in the burn. I will try a touch more air and see if there is a difference. All in all, the stove runs like a champ - just wasn't sure if it was normal to see smoke at this stage in the burn (as BB said, I always looked at the stack as the secondaries were kicking in to see if I was burning clean - I guess I just wasn't looking at the right time to see the smoke. Cheers!
Pen said it well, the diminishing stove temp, means diminishing stack temp. I have had this happen once in a while myself. With 27' of rigid insulated double wall, this thing has no problem drafting.
In most of my cases, it was the side pcs, and they were not as dry as I would hope or thought. Even old stuff at times. I been trying to leave a little space between the splits and the side walls, not much, just enough to let some air get along the sides. In the end, at night on cols nights, I pack it full, and let her do here thing. As long as I am getting about a mason jar full of brown dust at next years cleaning, I know I am in good shape and what smoke that does come out at these weird times and at start up, ain't amounting to nothing worth worrying about.
If this is your first year with the stove, just check the cap and top of the stack once a month or 2 to give you an idea of how well or not your burning, and that right there will tell you if it is going good or not.
