Pretty sure I have a (or maybe several) squirrels in the house.  Every fall I get the 4 or 5 field mice that migrate indoors to warmer climates, the original house is 1929 with a stone foundation, so they find their way in and the trap or the cat finds them. Easy.
However, now there's definitely something larger moving around. The mice are generally caught in the basement, this thing is in the ceiling above the first floor, below the floor of the second floor. It moves fast across the drywall, it's nails scratching along the same run every time.
I generally hear it about an hour after sun down and an hour before sun up, thus leading me to believe it's nocturnal, and thus a flying squirrel. The house has the vinyl siding on it that was on it when I bought it, and a metal screw down roof. I see no obvious points of entry, but I'm sure there's several possible spots under the vinyl as half the house has board sheathing on it. I'm a contractor by trade and generally refer my customers to a pest company when asked what to do about these things.
I'm close to ripping my ceiling down so I can see where it's coming in from, a search around the exterior showed a few suspect spots, but I lightly stuffed foam in the questionable areas (under roof flashing against a wall, open bottom of vinyl corner boards, etc...) in hopes of seeing it pushed out or in, thus telling me where the rodent is coming from, no foam has moved, rodent still there. Also not an every day thing, maybe 2 or 3 times a week.
Thoughts, suggestions, ideas? (I already promised my wife I wouldn't start shooting the place up, so that's out) The cat and the Rottweiler are terrified when they hear it, so they're no help either.
