st croix ashby-p stuck on pilot setting
Have you reset the control?
Try putting the control in thermostat mode, with the t'stat's terminals on the stove shorted together. That should eliminate a bad section on the mode selector switch.
Thanks for the quick reply. Tried your suggestion, no luck. Stove is 6yrs old, do you think I'm looking at a new control board? I cleaned the stove and changed the t'stat setting while wiping it down, with a dry cloth.
Try checking all the wires related to the t'stat inside the stove itself. Make sure none of the wires have slipped off.
Does the auger light come on at all? If so, how many seconds is it on - and does the auger turn for all the time the light is on?
