Need some help with the settings/ mode to run stove on. Renting a house that has a harman insert.
I’ve been doing research and sounds like running it in room temp mode is the way to go. I’ve been running it the last 4 days on room temp and auto igniter, feed rate 4. Temp between 70-75 and the fan on med-high. Works great but after it hits the temp it’s shutting out and then back on, feel like thats a lot of use on the igniter daily, and probably not good for it.
Trying to run it in same settings just manual igniter as I read the stove will not shut down, just go to a slow burn, the issue is the distribution blower doesn’t seem to come on. I had it on stove temp and my thermostat in the room said 77, I switched it to room temp, and manual and it’s now 70. And the fan hasn’t come on. Am I doing something wrong? Or is there a better way to run the stove? I know it takes some time to figure it out, just looking for some help!
Thanks
Thanks
