New Harman p61 room mode issues .
Spaztictyper
65
Nova scotia
I have a brand new Harman p61 and tried to use it on room mode. I switched it from constant where the room was 75. I set it on 1 (50) to see what would happen. I was expecting it to shut off but it didn't. The sensor is just stretched out from the back of the stove to a table 3 feet away which would be at the same temp. It's in my kitchen which is maybe 10x10 so it maintains heat well. I was expecting it to turn off immediately which it didn't do so I switched back to constant. Does it take some time to recognize the temperature before it reacts or is there something wrong? I never use it but thought I'd try it. Or should the status light go off indicating it's shutting down. I neglected to look at it. And never considered it takes 20 minutes or more to show any signs of shut down. Next time I'll spend more time and check the status light.
Reactions: Washed-Up
It does take some time before it will shut down because it wants to make sure it isn't a blip or random air current. Also, it depends on if the igniter was on or off.
It would be great if you would post a picture of your control panel settings so that we can see them while you have all these problems. It can be a great clue and sometimes we changed things and don't even realize (or remember it) it - like the ignitor switch is easy to bump on or off. Having issues is not normal with these P-series stoves - they are as simple as they get and very reliable.
Ignitor is always off. I want constant steady heat. I'm trying to figure out why the flame is surging from 1 to 2 or 3. That's my original problem . It won't "idle" See picture that's on 1, way to high for idle .
  • [Hearth.com] New Harman p61 room mode issues .
If you have the dial set to Room Temp, and the igniter switch flipped to disabled (or manual), the stove will not shut off, it'll burn at the lowest setting when the temperature has been reached. And then when the room calls for heat, it'll ramp up and put more heat out into the room.
If you're running in Room Temp mode, don't change your temperature dial, just let the stove do it's thing. Any changes you make could take 15 minutes for the stove to make the change, but then more time for the pellets to burn down after making the change.
I run my P68 in Room Temp with igniter disabled (manual) and set to the temperature I want the room to be. My thermostat wire is coiled up and taped to the back of the stove.
Here my settings and a picture of the resulting fire. Ignitor is on as I need the fan running. It's as you can see pumping out a storm. If I turn the fan off (ignitor off) the fan turns off but it continues to feed at more then 1 rate see the picture. Will the fan come on with the auto ignitor off, my understanding is it won't and doesn't under these settings and the house cools down. Should I move they temp from 1 to let's say 4 and see what happens? With the ignitor off? Will the fan come on? I ran it in this configuration and it put out very little heat. And the fan didn't come on. It's now to the next picture and it's cooking in here. But it will continue to go up and down. Still trying to grasp what your saying. With the fan not running it won't in my experience heat the house. Once I get an answer I'll try it on 4 with the fan off. I'm extremely tired and takes some thinking to grasp it. I run it in this mode because my old p61 didn't have an ignitor so it couldn't restart and it worked fine. I like it left in a mode where it never shuts off. Which it wouldn't. Most important to know if the fan will come on with the ignitor turned off under any conditions. This is what is confusing me. And I'll ask again in this mode should it not run at the set temperature with ignitor on? And will the fan come on? Seems to me the old one did. Making the question here, You can see the settings, why is it humping out heat? Ignitor is on so the fan works.
Thank you all for their input.
Check the Temp Dial:
In Stove Temp (Constant Burn) mode, the distribution fan will not turn on unless the temperature dial is set above 5. This is a cut and paste from an article. This also baffled me it hasn't been past 2 and it's on 1 now blowing away. With out it on Id never get any heat. I also turned the feed rate down to 3 and it doesn't change anything. The other thing is it should run off the ESP temp based on the dial setting in constant mode because it obviously isn't?
Turned the feed rate down from 4 to 2.5. Still pounding out heat. I'm supposing it might just be too warm out, 800 sq feet normal amount of insulation and it's 40f out still 75 to 77 in here.
Have you tried it on 3 and 1? In auto, I realize you don’t want to use the ignitor… however to chase the temps you want I think this maybe the answer….same stove here and have NEVER had anything close to the issues you have posted about
I've come to the conclusion, that it was to hot outside. I've found a tech who's coming Monday hopefully with the proper equipment, more then.
I agree my 30 year old one ran better. Not very impressed
If have to agree, turn the feed rate down, from 4 to 2.5. Flame went down but temperature didn't. Still mid 70s in here. Once the sun goes down it's somewhat better.
Look behind ash pan for properly indexed combustion fan cover with cutout. if it does not fit perfect it will allow positive pressure exhaust to blow back into stove and cause excessive flame and heat and incorrect reading at ESP Probe.on my P68
2 months old the latch assembly was mounted a few degrees off tilted to left causeing 1/4 in gap at top and bottom and was shipped that way. good luck
Reactions: Washed-Up and ARC
If I crack the door will it suck air in? Or just more air? I'm still running it, despite it's baking in here. it also cycles ( again on1) with fan off from a half inch flame to 4 inch flame. It's feed rate is 3 and it set on 1. Tech is coming tomorrow (supposedly) so I'm just dealing with it.
Door open sucks in air, yes. Fire will be poor quality! The stove will shut down; the vac switch will see it as no vacuum, indicate a fault and shut down
So DO NOT RUN STOVE WITH DOOR OPEN
I will be blunt: put your stove on a stat in the on/off configuration! Yes, the stove will shut down and restart when there is a heat call.
I know it is hard on the igniter. This is the only way that you can control the room temp when it is above the freezing point and lower . This also depends on how tight your home is
Lol I wasn't going to run it with the door open. But I am trying to remember how I used it last year. I believe I had it on constant and used the number scale (1-7) to control the temperature. Does it use the wire thermostat or do you guess what number you use. Obviously I'll have to mess around with it. Ignitor off ( I like constant heat) and adjust it from 1-7 for the heat I like? And the fan speed. I remember picking a number. Right now I'm on 1 and just using the fan to control the heat level, but as it gets colder I'll need more heat then 1 gives off. High 20s tonight and 50 tomorrow.
If you wire in a thermostat, place the thermostat in a central location away from the stove and away from the air stream from the combustion air. Otherwise it will short cycle and you won't like the results.
I use a basic Lux, battery operated thermostat on both my stoves.
Use the external thermostat for the setting you actually want. The temp dial on the stove should be higher than the wired thermostat temp - I put mine in the 80s. Since I wan the stove to run longer to ensure the exhaust pipe gets up to a good temp to discourage creosote, I have the feed rate at 2.
If you are using really good pellets, that run super hot, that may be an issue. My P61a will gunk up because it will still warm up the room too fast and gunk up the inside. I use middling pellets for the P61a in my 600 sq/ft basement and it works well. Before I insulated the cinder block walls, it would run the hot pellets really well because it had to work hard at fighting the cold from the cinder blocks. If I had gotten a stove after insulating the walls, a P43 would be more suited to that area.
Don't worry about the igniter, both my stoves have original igniters.
In your case, maybe turn the dial up to room temp, and keep the stove on Auto igniter. The stove will get the room to temperature, then turn completely off until the room calls for more heat, then it will start back up again. I don't like this mode because then your house is hot cold hot cold... but maybe it would work for you better than the constant burn setting that you don't like.
Quite the opposite, I'm the same as you I like a steady heat. I've also decided to get rid of pellet stoves as the company who I bought it from won't come and look at it. I'm trying propane stoves. Brand new stove with nothing but issues. Probably going to be a month before I get everything sorted out.
