If you can't get the shaker plate out, try this: leave the door open, and start the stove. The Versa will run, but the stove won't start because it will get a #2 fault (vacuum loss). You may have to do this up to three times, depending on where it originally stopped, but you will be able to get the plate out to clean it. When you're done and the door is closed, the stove will start up normally. Works for me.
(Make sure the plate doesn't catch on anything if you have the burn pot removed. I just guide it with my fingers so it doesn't catch on anything.)
Thanks for the tip - I'll be using it in the near future I am sure
