Do you get a blinking light on the control panel? Either #2 or #3 blinking indicates a particular problem.
ryan319 said:I don't have an air intake tube.
Could my combustion motor be getting lazy? When I first started the stove this season I got the #2 light and I had to help the motor get started and it really wasn't all that dirty. Once I cleaned and freed it, it runs but maybe is just slow. Would that also explain why my fire slowly fades, especially when I turn up the heat?
Thank you to everyone that has responded with ideas.
SmokeyTheBear said:ryan319 said:I don't have an air intake tube.
You most certainly do have an air intake tube, the fact it isn't a long one doesn't count. It is where an OAK would connect and the area just before aPond after where the damper is. It ends at the burn pot.
DexterDay said:Is this a Fasco motor? If it needed help. Then some oil would work wonders!
ryan319 said:this thing has me beat. the ash traps are clean, and i went up inside them with a long flexible cleaner similar to what they used in the st. croix video. i cleaned out the combustion fan by removing it and blowing through it back into the stove. the pipe going up the chimney and cap are free and clear. i cleaned the intake blower. i can't find any significant buildups of ash left in this thing. i've had all the brick and everything inside the stove out and cleaned it. after cleaning it again for 2 hours this morning the flame is still the same weak and almost smoldering out.
when its in startup mode the flame is big and powerful like it should be but when the combustion fan kicks in the flame dies out. is the fan going bad?
what am i missing?
let's assume that the stove is completely clean, what hard part failures could cause this?
rickwai said:the long handled wire brush that comes w/ a harman accentra insert is perfect for cleaning the ash trap chambers to the top of the stove. I will bet it is clogged in there
ryan319 said:the saga continues.
i had a service tech from the local dealer come out yesterday. he said that the stove was nice and clean but that it needed a new door gasket. i countered with "i just changed the gasket and it didn't make any difference in the performance. i think that its something more than the gasket. maybe test the combustion motor." he declined to test the motor and assured me that the new door rope would fix the issue.
well guess what, it didn't. so now i have confirmation that the stove is clean and a new door rope but the stove still sucks. it flamed out last night after running for about 10 minutes and the #2 light was flashing. i restarted it and it eventually stayed lit but you couldn't even see the flame about the fire box on heat settings 2-5. setting 1 seems to be the only one that works a little but the flame is still really weak. i bypassed the vacuum switch and it didn't run any different.
so after they charged me $115 for the service call and gasket the gd thing still doesn't work right.
should i just replace the combustion motor or what? what else could it be? i can't see how the control board could go bad.
ryan319 said:also, i noticed when i was messing with the stove last night that the board was somewhat unresponsive when i tried to change the heat level. relevant?
SmokeyTheBear said:ryan319 said:also, i noticed when i was messing with the stove last night that the board was somewhat unresponsive when i tried to change the heat level. relevant?
Not likely, on a number of stoves there is a delay between the selection of a heat level and the stove actually changing the feed.
