Made a newbe mistake and thought I could kill a fire by closing off the air in my VC Vigilant before going to bed. Instead I made a creosote factory. My chimney is lined with stainless and has good draft but how do I clean this mess from the outside of the stove and the outside of the stove pipe. It seeped through the joints on the 90 degree elbow and since the stove pipe has the connections in the wrong orientation, it also dripped outside of the pipe instead of inside the stove.
I'm pretty sure I can use something like Third Stage Remover for a while to get rid of anything on the inside of the chimney, but how do I clean the stove and the outside of the pipe? Should I just buy new stovepipe?
Thanks,
John
Thanks,
John
call a chimney sweep to clean it properly. They have the ability to do it better since it is so messy. Then the next time you should be able to do it yourself. Live and learn I guess. Good luck.
