anyone have any info on useing a propane tank for storage. How is this done?.I have actually found some good prices on 500 and 1000 gal tanks new and used .
verne said:what do you guys think about a 1000 gal propane tank with an eko 40 .also what kind of pressure would i be looking at 2-3 pounds? I have neighbor with propane bussiness he has a new tank with apin hole at the top weld . getting close to breaking him ,dont want to push too hard without a need.
verne said:Is a closed 1000 gal much different than an open storage. Nofossil I see you have 880 with the eko 25. At this point I have only oil boiler and side arm to suply. so I think in light of the price I would be better off with a pressure system other than none at all? What do think?
verne said:lead dog, that's exactly what the propane guy told me. He said the leak is so small it probably would fill with rust and be no problem. they test tanks over 200lbs. Zenon emailed me and said the same thing about expansion.the only problem Ive had is the propane guy sells heatmore , so access to hunt my property is payoff. thanks for all the help everyone. Im going to need alot more as I move along. Time to price the barn .Storage room getting bigger to hold a 16' long tank. I'm a carpenter so at least I have a clue with pole-barns.
verne said:I was told I needed larger expansion but not how large
leaddog said:I was wondering about oxygen being absorbed from a non-bladder tank and is it a problem in a closed system. Would it be better to charge the tank with nitrogen. If you used nitrogen would it desolve in the water like air does .
atlarge54 said:Storage with water looks complex and expensive, expansion, corrosion, etc. Has anyone tried an insulated box full of pea gravel with a pex loop inside? Seems like it would eliminate expansion problems and pex seems pretty darn cheap to me. A crude estimate tells me a 4' or 5' square cube could replace 1000 gal water. I've got less than $3000 in my entire system (no storage). Bought junk Global hydronics OWB $300 wrapped firebox in copper tube replaced water jacket and filled with pea gravel for thermal mass. All this runs through a side arm heat exchanger for domestic hot water then to a pex floor radiant system with a small water to air exchanger for really cold days. Oh and I don't use the blower on the OWB the aquastat set at 130 F only opens the air supply. That blower on the OWB looks like a HUGE WASTE of heat out the chimney. I,m only heating a modest home so this system isn't for everybody. I've had a fire going every day for about 2.5 years now winter and summer. The boiler is off more than it is on. Pex in floor radiant is great I highly recommend especially for new construction.
