Stove Bright satin black over Enamel
Defiant
Vermont Castings Geek
2,128
Old Lyme CT
Do not know if any of you have tried this but due to the request of a friend and customer I did up a VC sand enamel Sequoia. Looking for feedback if anyone ever did this. I will keep you posted on my results, I'm kicking in an extra can for touch-up. Looks good now but no guarantee on the paint job.
As long as you dull the enamel with a good sanding it should be fine. 220 grit. It worked on an antique cook stove. I wiped it down with laquer thinner as well since some of the cast iron had been touched up with stove black over the years. I fire them up outside with a few pieces of stove pipe and burn the worst off outdoors. They take to hauling around better with the paint cured too.
Thanks coaly, good advice that's exactly what I did. Looks rather nice.
It'll flake off after a few fires.
I'd like to know how effective this is long term. My standard answer to people for 26 years was "I wouldnt do it. Cant paint a glassy surface with stove paint, it will slide right off" Kinda like Summit said. This will be an interesting experiment.
I sanded and painted the sides only, of a Buckwalter "Real Apollo" cook stove with 6 eyes and oven. The sides don't get as hot as the front door, which wasn't bad, so I was able to shine that up with automotive fine rubbing compound (a white paste 'safe' for clear coat, so it's not very abrasive) The top that gets the hottest is seasoned like you do a cast iron pan. I painted it at least 10 or 12 years ago, and the paint shows no sign of flaking or wear. If the top gets to 500, the sides maybe 200 ? with the oven in operation over a few hours at 300 to 350.
