Stove recommendation's. Help me find a nice stove./
I like the look of the osburn 2300/3.1cuft with nickel door and legs. Would have went with that if it fit my application. My 1800i has performed nicely and have no real complaints.
(broken link removed to http://www.osburn-mfg.com/product.aspx?CategoId=1&Id=548)
Somebody point me to posts about a reburn tube failing. Been here since 2005 and must have missed them. The ones in my stove are $28 apiece if one ever decides to look like it needs replacing. One screw and it is out and back in. Stove is in its sixth burn season.
Most of the ceramic baffles that I have seen that needed to be replaced could have been avoided by taking the stove owner's poker away from them.
Reactions: bholler
A lot of good non cat stoves out there. PE, Lopi, Englander, Jotul, Osburn and Buck just to name a few. I almost bought a Summit to replace my Lopi Endeavor but knew I wanted a cat stove for my next stove and went with the Blaze King.
Keeping America Warm said:
War Horse
Sounds like you have already doing your homework, "nocat" is smart!
Been doing this for 34 years now, (but still learning) :)
I really hate to side track this thread since the OP is looking for a non cat stove.
Can you take some time and explain why you feel this way in this CAT Talk Thread? A lot of us cat users always wonder why such bad advise is given out from hearth retailers. Is it as simple as you don't sell cat stoves so don't recommend them, think they're still like the early cat stoves that were made or don't think the consumer is smart enough to burn dry wood and flip a bypass lever?
As a previous non cat user(Lopi Endeavor) I can say I don't ever see myself going back to a tube style stove.
This was a Lopi related thread I was referencing.
https://www.hearth.com/talk/threads/49284/
I just read a bunch of posts on the blaze king and I think I just came down with BLAZE KING SICKNESS. I want one so bad. I wish now I would have gotten one instead of the liberty. I know the liberty was going to run hot but I didn't think it was going to cook us all the time. I would LOVE to be able to load every 12 to 24 hours with the liberty but that's not going to happen. If I thought the princess model would heat the house I guarantee you I would have one. If ANYTHING every happens to the liberty I would not look at any other stove except the blaze king.
Missed that one somehow. I can't believe Travis has a stove with mild steel reburn tubes in it. Dumb.
I'm pretty sure my Endeavor had stainless tubes in it, not sure if all their stoves us stainless but I'm 99% certain mine were. There was another thread somewhere that stated they changed them from mild steel to stainless somewhere along the way.
Yeah... it sounds like they shifted to SS on the Endeavor at some point. I have no idea when though.
I thought they updated them to stainless a while back? A friend just got a new set of tubes for a 12 yr old Endeavor and he said they were stainless, but I haven't had a chance to check that out.
Ah, one of the stoves I was referring to. When you get into replacing tubes, baffle supports and bypass supports it can get very pricey. I love these stoves(including mine) but it is a cost that should be considered if you wanna get down to it. A cat is so simple to change, and they last for a good while.
A set of tubes with collars is like $62. If the new ones are stainless, this is a non-issue. Bypass supports? Is this a BK item?
Treacherous said:
webby3650 said:
Treacherous said:
webby3650 said:
Non-cat stoves will need repair/maintenance after many years as well and it's gonna be a whole lot more expensive than a cat.
Somehow I don't think the air tubes are more expensive than a replacement cat.
Well you could be wrong depending on the stove. Some stoves have alot more going on than just tubes. Most people would have to pay a tech to do these repairs and the labor cost can be pretty high.
I can't imagine all the tubes failing at once and cost is probably $40-$60/piece IIRC. I've heard some say they fail in 2 years and some say they have the original ones after 10 years. I also do all my own repairs when possible so that cost is not something I probably have to consider. Aside from the door gasket and possibly adjusting the nut on the stove door handle I'm not sure what else would fail on my Lopi aside from some major welding defect that manifests itself years down the road after my warranty is up.
Don't get me wrong... I would consider a cat stove but everyone has their own reasons for selecting the stove they do.
If you can do the work yourself then you are right, it's not a big expense, and the tubes should last a whole lot longer than two years, what happened there?
The dude has thought about it, listened to the pros and cons, came back and said he wants a non-cat. End of story, give it a rest. If he doesn't want burn tubes, there are other options in the non-cats like the PE. I'm not knocking cat stoves, but this horse has been beaten to death.
  • [Hearth.com] Stove recommendation's. Help me find a nice stove./
Reactions: bholler
BeGreen said:
The dude has thought about it, listened to the pros and cons, came back and said he wants a non-cat. End of story, give it a rest. If he doesn't want burn tubes, there are other options in the non-cats like the PE. I'm not knocking cat stoves but this horse has been beaten to death.
x2, plenty of wonderful stoves available capable of doing a good job heating. I would love to burn a different stove every year just to get a taste of them all, obviously that isn't going to happen unless I hit the lotto or something. :)
Reactions: tash
Think I am going to take the price difference and order 81 spare re-burn tubes. Just to be safe. :lol:
Or just put two whole stoves in the crates in the garage for backup.
War Horse
here's what i posted there FWIW....
well,
i’ll take a stab at it ;
for the record we built cat stoves frm the late 80’s through the early 2000’s before going to non-cat totally.
cat stoves have advantages and disadvantages just as non- cats do, biggest thing with non-cats is ease of operation. you literally can burn it like an old dragon, load light and go. cat stoves typically are a bit more involved. both do very well in controlling emissions however so the “clean burn IMHO is virtually a wash. burn times with cat stoves do generally stretch out a bit farher than non-cats as well, but non-cats typically rate higher in “btu/hr †which makes sense if ya think about it, faster burn time means faster release of energy. as for the fire itself, cat stoves (at least the ones ive operated) tend to make a lower smokier fire (which fuels the cat and lengthens burn time) this kind of fire isnt the most condusive to a clean glass or for that matter in my mind less attractive to look at. also in most cases cat replacement is a more involved task than changing say tubes and refractories in a non-cat. draw factor can be a point as well, typically a stronger draft is neeeded to “pulâ€â€ a cat stove than a non cat and a marginal draft can make a cat stove more finicky to operate at a reasonable rate than a non-cat.
now, all that is mostly my opinion, but looking at it from a builders standpoint, cat stoves (at least the ones we built), were harder to build and more labor intensive. our “non-cats†are much easier for us to manufacture.
from a “service tech’s†standpoint, the easier operation made for far and away less “my stove dont draw†calls.
as for dealers, one , they sell more non-cat units overall now than in the past and many who have been in the buisness since the “phase 2†inception probably have a bit of a bad taste in their collective mouths from the early days of phase 2 which was fraught with hastily designed “gotta have somthing we can sell†units which came out in the earliest years of phase 2. many of these stoves were dogs to be quite honest, clunky and hard to operate. newer more thought out cat stoves are the norm now and a lot of the issues with first generation cat stoves are a thing of the past, but the bad taste probably still lingers.
FWIW i like cat stoves as i do the non cat, but im a seasoned veteran of burning phase 2 stoves where a lot of new stove owners arent and typically struggle with operating a cat unit. in my opinion though, when run properly there is nothing wrong with either type of unit and as far as one being better than the other its kindalike the “ford chevy†arguement
The dead horse that was taking a beating above has been buried. lol
I have it narrowed down now.
Englander Model 30 vs. Pacific Energy Summit (not the Classic Summit)??????????????????
Which one has a larger usable firebox???
Which one has Thicker steel?????
Which stove is more North to south load friendly????
Anything comment's you would like to add will be appreciated.
Which one has a larger usable firebox??? Englander is listed as 3.5, Summit 3.0, usable space? Not sure, damn close.
Which one has Thicker steel????? PE has the thicker steel, but Englander is step topped to add strength, So dead even there more or less.
Which stove is more North to south load friendly???? Both are N-S friendly, so dead tie there.
Englander $899.00 at Home Depot, can be found on clearance sometimes for $476-$500+
PE plane Jane Summit prolly around $2,200.00 range? Both will put out plenty of heat, and get 8-10+ hours burn time.
Basically are you IMO, go for the Englander unless your looking for something fancier. The plain Jane Summit ain't all that fancy. If you want a Summit yet fancied up, look at the T6. Same stove with a cast iron jacket. T6 about $2,600.00 range.
Some of us prefer to stock it with wine. LOL
Ha ha Thats a funny photo. The stove will keep you warm on the outside,and the wine will keep you nice and toasty on the inside. I think I'll call this combo the Baked Potato. I like Lambrusco Riunite myself.
Hm, I wonder what the Republic has. I am thinking it's not SS, but will keep this in mind if/when we have to replace them in ours, since the Endeavor is pretty much the same stove.
Sure if you can change them yourself, if not, they will come from the dealer and this can drive the cost way up. It doesn't really matter, all I'm saying is it will cost you something for maintenance either way you go. I have ,and have had, several of both. I think BKing has other cat stoves whooped with burn times, and in this case especially, ease of maintenance. Anyone can change the cat, so a few hundred bucks every once in a while is a bill I'd be glad to pay. And no I wasn't referring to the BKing, it's a cat stove. Well they have non-cat, but who has 'em. :lol: I was referring to Lopi stoves with bypasses. Sometimes the back baffle support/bypass frame, gets warped(usually after the second set of tubes). User error? I think so, but the operator sure never does.
I know this is an old thread, but thought I'd give my update here.
I want to thank everyone who helped educate me here.
Bought the Englander!!
The Englander 30 NC stands on my hearth.....and I'm telling you there ain't no other stove. I couldn't be happier. It's probably 15 degrees out right now,and were warm. Thanks to you all,and Englander Stove Works.
Sure you can get a prettier stove but I'll tell you from experience....just cause it looks good doesn't mean it is good!
