How much should they differ if they should ? I'm having issues with my stove/stove store and they think I have an overdraft problem. They want me to check the two temps. and see if heat is going up chimney hence the overdraft issue. They are coming out Wed. to check out stove and draft. I don't think I do because my glass is all smoked up when I choke it down overnight. If it was overdrafting it would be clear. This has all come about because I told them they sold me the wrong size stove for my house. I just want to return this one and spend $1k more for a bigger soapstone instead of my Avalon but they are giving me the run around with every other excuse except saying yes we made a mistake and we'll make good on the deal.
I've got a 20 ft 6" SS liner anyone know how much draft ? I need some numbers to compare to stove shops. Their credibility is shot from previous issues. I'm also calling stove manufacturer
! My oak has been split for over a year so I know it's not that. I'm only trying to heat about a 1000 sq ft of open floor plan. Stove is rated for 1800 so if it even did 1500 I'd be all set. How much area do you heat ? No I don't have block off plate installed because stove will be returned. What temp. do you run your stove at. I run mine 450-500 and at 550 it'll put some good heat out. Now if I need to run my at that high of a temp. I would say it's too small. I've gone through a cord of oak in a month and it hasn't been very cold here. You can't tell me that I should go through 5-6 cords a year. My parents had a old Vermont Casting which only used 2-3 cords 24/7 and that was back in the early 80's.
