Tried to light the stove for the first time this year won't draft at all. Filled the house up with smoke After getting it out and fans going saw a large bee in the bottom I think a eviction notice shall be served
Did you try warming the flue? Might just need a little heat to get the draft going.
class a triple wall what are you thinking??What do you have for a chimney, class A or masonry? If class A, double or triple wall?
I have a short chimney and always have a ball or two of newspaper on top to send a slug of hot air un the chimney first. Maybe not needed 99% of the time but little chance of smoking the house up.
If you have a fairly tight house cracking a window can help a bunch at times too. Mine is 140 years old so plenty of leaks here.I will do that every time now
