Hi Group,
I just started installing a newly ordered Stainless Steel Chimney Liner Kit last Friday, but then ran into a problem.
I got the 15' section of S.S. Liner Pipe, down the chimney, from the roof, along with the vertical section of the connector Tee on the bottom.
The problem occurred, when I tried to "slide the horizontal 10 inch section of the connector Tee through the Thimble/opening, to connect into the bottom, vertical Tee connector, in the chimney".
The old/original (circa 1930) clay pipe/tube with thin metal ring on the inside wall of this Thimble is 1/8" smaller than the 10" horizontal section of pipe, that I am trying to "just slide in".
So it does not slide in...
Now, I could grind/chip/cut out the inner wall of the Thimble, enough to get this pipe to go in.
- I'm not all that comfortable with having to do this.
COULD I cut the 10" horizontal pipe down the middle, then slip this just inside the same pipe, then JB Weld the seam (like welding it up) to seal it, from all the hot smoke/gasses.
This WOULD work, wouldn't it???
I'm stuck here, guys, and am reaching out for any other good/safe ideas, on how I can get this installed A.S.A.P.
We're supposed to receive 8+ inches of Snow tomorrow, then single digits overnight, later in the week.
Any ideas will be greatly appreciated.
Thanks!
CTwoodnutt - Peru, Maine
Thanks!
but that's not an option).
