Hey,
I have a few questions for this group. Been reading about several things on and off while I was building my hearth. I went with a 1 inch airspace behind durarock and slate tile. Works perfect. I had bought a Waterford wood stove although the thing was nice looking it did not heat our rooms well enough and went through wood big time. I just purchased a Lopi Leyden and so far after one night of burning love it much better stove and heats really well almost too well.
Heres my first question. With a Lowes bought chimney system through the roof and ceiling I have a 5.75-6.00 inch dia connector on top of ceiling. Will I be able to hook a straight (or an elbow) of double wall pipe to it? Even though the connection piece is single walled up to double wall insulated. I realize I have to connect double wall all the way down but am weary about what fits on the SuperVent system.
Another question is my clearances all seem to be within manufacturers, but one is a bit close which is the front clearance. Will that be a major problem with radiating heat on a wood floor? I bought a fire resistant rug, and felt how hot it got last night and there was not a huge difference in temperature directly in front of stove.
I spoke with my fire department and explained what setup I had he mentioned as long as theres airflow on any combustibles I should be fine. While going through the roof the contractor cut through so that the double wall insulated was actually touching one of the rafters. I was able to cut out about .5"-1.0" of material out of the way but manufactures says 2" min. What is your take on this is it safe? The pipe itself does not get hotter than 200F while burning. Is there anything I could place over the gap or should I cut more away?
Thanks
Thanks
!! I was scared safe.
