Hello to all.
My question today revolves around a Superior SLDVT-35NE direct vent fireplace that has been installed into the home. The manual has not been very clear with instructions in regards to the electric wiring.
I have installed a rocker switch into the bottom control panel to turn the fireplace on/off but was under the impression that I could also install a CPI switch along with the rocker switch to enable the pilot light to remain lit during cold winter periods and to prevent moisture on the glass at initial startup.
Is this something that can be done with this unit, and if so what would be the best way to go about wiring this.
Thank you in advance!
