Taco I series valve
Rob186
42
New jersey
I found a modulating thermostatic valve from taco and was wondering if anyone thinks it could be used as boiler protection it is only 1" but it is a ball valve type and full port it is taco setpoint I series if someone thinks it can be used I'll draw up a pipe diagram
If someone knows more about thermostatic valves as boiler protection and the pipe sizes available please do tell =) At one point I was looking at them because they just make sense.
I don't see why the I-series wouldn't work, but at 1" and the cost I'd go with a non-electric thermostatic valve. Plus if the I-series ever stuck in the bypass position or the motor failed it would make a big boiling mess.
TS
Here you go.
(broken link removed)
Or here for the cheap, a real thermovar too.
(broken link removed to http://www.ebay.com/itm/Wood-boiler-return-water-temperature-protection-valve-Thermovar-LK-820-/170905631468?pt=LH_DefaultDomain_0&hash=item27cac4faec)
TS
Non electrics are just as capable of sticking as the rotary ball in the i-valve.
Check the model of the i-valve....many of them have the capability to provide boiler protection built in.
(broken link removed to http://www.taco-hvac.com/en/products/i%20Series%3Csup%3E%26reg%3B%3C/sup%3E%20Mixing%20Valves/products.html?current_category=184#)
