Hi all,
The weather in the Chicago area has been staying in the single-digits of late, and my otherwise perfect draft is not so perfect. This evening's fire got the stove up to about 250 F before I had to feed it more kindling. When I opened the door, smoke came in after about 5 seconds. I keep my furnace thermostat at 45 F when I'm not home, so I assumed the draft problem was because the room air was too cold, so the cooler air drawn up the flue with the door open was not buoyant enough to maintain a draft. I used the furnace to get the house up to 60 F, at which point the same thing happened when I opened the door. I do not have any smoke coming out the air intake when the door is closed. The stove is a Lopi Answer set in my fireplace. The house is 2 stories, making the chimney about 20' tall, which is masonry, clay tile flue and on the outside of the house. I don't remember ever having any draft problem. Is there any way to work around this? Right now I'm not getting much heat from my stove and I can't open the door to build a better fire.
Thanks,
Scott
Thanks,
Scott
