You are right, was just a reminder, at the red glow that many manuals indicate, to determine, overheating, it seems that this happens above 1000 F, so at 600-800 we still have a lot of safety marginIt is (at least *in* my stove) impossible to assess the temperature of metal using such a color table, because this table assumes black body emissions, and when something is that hot, it certainly is not a black body. Instead it also reflects a lot of the ambient light of the flames.
I used to be able to judge the temperature of silicon by its color from about 650 C up to 1300 C with a precision of at best 25 C simply by looking at it when it is inside an otherwise dark vacuum chamber. I have never been able to be confident in assessing the temperature (e.g. of the cat or the flame shield in front of my cat) by color in my stove.
Thank you !!You are right, was just a reminder, at the red glow that many manuals indicate, to determine, overheating, it seems that this happens above 1000 F, so at 600-800 we still have a lot of safety margin
If you run it wide open it will without question overfire. Wide open is only used for startupConsidering the stove manufacturer said 800 was fine yes but I only get it to 800 that’s the high I will do, and the dealer said the same thing. I asked how hot can I get it he said 800. But when’s it’s at 800 the temperature is on low.. it’s not wide open
I would not reason like this. Red glowing is (by far) too hot for the metal and the welds.You are right, was just a reminder, at the red glow that many manuals indicate, to determine, overheating, it seems that this happens above 1000 F, so at 600-800 we still have a lot of safety margin
Yeah it’s never wide open. Only wide open doing start up. But when’s it’s at 800 the air is cut backIf you run it wide open it will without question overfire. Wide open is only used for startup
As expected. The high temp can be reduced by the way the stove is operated. This is covered in the other threads on the same topic. The stove will be ok running regularly at 800º but with greater stress on the internals and therefore shorter lifespan.Yeah it’s never wide open. Only wide open doing start up. But when’s it’s at 800 the air is cut back
What makes you think that?I'm thinking 800 is way too hot- ideal STT is 400-600, you're not stressing out the stove, your burn time is maximized and all is well.
That is typical. 800º is pushing it.Mine seems to like cruising at 650.
