Actually I have 2 questions. The 1st is, Why do the clamps continue to loosen that hold the glass to the door on my Jotul Castline 400? Last year my glass cracked and I had to replace it. After I replaced the glass every once in a while the clamps that hold the door glass in place would loosen and the glass would fall. Can I use Loctite on them or are they getting loose from use and should the be replaced? The glass is the same thickness as the old glass.
My 2nd question is where the clamps are (and when they are tight) I'm getting a lot of build up like creosote. I did replace both the door and glass gaskets last year. Even when I replaced them the glass still had that look like there was an air leak. How can I stop that?
