Thanks, I wish I was a young manWoooo-hooo.... congrats, HDR. That is a good looking fire.
There are a few quintessential moments in a young man's life... his first fire in his new woodstove must certainly be one of them.
Most of age is a state of mind -- except for my bad knees, of course. Those are just old knees.Thanks, I wish I was a young man
This is something I am not sure about , once U get a fire going how to load it up and not have it all going off at once.I also pack it pretty darn full but am mindful of it all going off at once
Could U define cigar burns ? are the secondary's working during this ?I rake the hot coals forward and like to do cigar burns on overnight loads
A cigar burn is N/S loading. Wood burning from the front to the back.
Oh that makes sense, I have been wondering about the N/S loading deal, it didn't really apply with my old stove.
So does N/S loading generally give you longer burn times ?
what's the advantage or disadvantage of loading N/S ?Maybe it does for others, but not in our stove.
Thanks for the reply.Good questions... For longer burns you'll want to rake the hot coals forward so the majority of your split's surface area isn't in direct contact with the hot stuff. This delays the burn slightly and burns from front to back. For over-night/long burns, keep the wood tight together. For shorter/day time burns, you can have more space and/or throw in a few logs rather than pack it full (short, hotter fires are best). Your stove may have a spot that burns better than others. You'll also want to learn how your stove reacts to start-ups and re-loads (ie, how long does it take to cool vs. how long does it take to heat up to proper burning temps). I learned quickly that you never put a full load directly onto a hot coal bed, it'll off-gas and get your stove pretty darn hot haha. If you do this have a box fan pointed directly at the stove, shut down the air, and ride it out. There are a bunch of threads on here about stoves going nuclear and other ways to bring 'em down to temp.
Depending on moisture content and possibly the type of wood, I'd say the secondaries keep firing until the fuel is close to losing its shape and becoming a pile of coals. On a good load last year we had 'em firing for several hours with only a minor air tweak or poke.
Really !! open the door ? When you have the air control shut down ?If your stove goes off and it is way to hot, open the door all of the way, the large amount of cool air cools everything down, you can toss a few scoopfuls of ash on the fire while the door is open, and when the temps come back to normal close the door, keep an eye on it for a while but everything should be back to SOP.
What mods did you do?Enjoy the new stove let me know if you want some info on mods I have done, or anything else.
How often do you need to clean out ashes ?For longer burns you'll want to rake the hot coals forward
Thanks AugieDepends on the outside temp, the wood type your burning, how long your willing to let coaling stage go. Shoulder seasons I was getting away with once every 2-3 weeks, heart of winter maybe once a week, those really cold weeks, maybe 2x a week.
The stove runs better with a .5-1 inch layer of ashes on the bottom to provide some added insulation. after that is is a combination of how much you are willing to let get built up before it starts reducing the size of your firebox/ spills out the front.
Do you take the stove pipe apart when you clean the chimney ?
Yea ,I took out the baffle bricks, the supports and the rear baffle plate to reduce weight before moving the stove in the houseYea, once you have done it a couple of times it is pretty easy.
I finally remembered to grab my manual and look at where they have the thermostat located. It's like I remembered, vertical in the back convection chamber, not in that horizontal chamber where your manual (and the Travis online manual) places it. I'll call the dealer tomorrow and see if we can get a snap disk extender ordered up. Here's the page from my manual:The snap disk has to be attached to the other metal part the snap disk extender , once installed in the hole ,the snap disk will contact the bottom of the stove, with out that other metal part the "snap disk extender" U would not be able to install the snap disk correctly .
That's why I had to order that part from a dealer the other day, I have every thing else for the blower except that part "snap disk extender"
Maybe that was missing when U got the blower new
Did U install it in that position and try it?I finally remembered to grab my manual and look at where they have the thermostat located. It's like I remembered, vertical in the back convection chamber, not in that horizontal chamber where your manual (and the Travis online manual) places it. I'll call the dealer tomorrow and see if we can get a snap disk extender ordered up. Here's the page from my manual:
It's kind of unclear , your instructions say to be sure the snap disk is touching the fire box but, it doesn't say if it should touch the back or bottom of the fire box, looks like they mean the back of the fire box though.
Do U need the snap disk extender to install it in that way ??
Does it say any thing about the using the snap disk extender on another page, or at all ?
If U want to install it in the channel with the snap disk extender, this is what U need , Snapdisc Braket (1750) part# 250-01370 ,It friction fits into the vertical space without the extender, but kept sliding back down when the stove would heat up (and I'm assuming the space would expand).
I've contacted the sales guy and asked him to provide the extender (it's not included or mentioned in the rest of the manual).
I also figure I could stack it on some tile, or just fold a support out of a piece of duct metal to get it into contact with the bottom in that left convection chamber.
Thanks. I haven't heard back from the dealer yet. Do you think just bending some light weight metal (like duct work) to create a table to wedge that thing on would also do the trick? Or does there seem to be something special abot the snap disk bracket?If U want to install it in the channel with the snap disk extender, this is what U need , Snapdisc Braket (1750) part# 250-01370 ,
