theoretical question
Yes. Law of conservation of mass.
pen
No you will not get a 1lb of whatever leftover from burning 1lb of pellets.
What about the heat, the energy used to heat aren't recoverable to "weigh"
Imagine finding the weight of an empty tanker with 1lb of pellets in it. Then you seal the tanker and let the pellets inside burn. If nothing goes in or out (other than the heat energy) the mass will stay the same.
In a case like this you just changed the type of matter, you never destroyed an atom, just rearranged them. The energy was found in the bonds that held the original compounds together.
pen
Reactions: tjnamtiw
If all the byproducts of combustion are conserved, yes you will. This is why chemical equations must be balanced.
The Law of Conservation of Mass
  • Established in 1789 by French Chemist Antoine Lavoisier
  • States that mass is neither created nor destroyed in any ordinary chemical reaction.
  • Or more simply, the mass of substances produced (products) by a chemical reaction is always equal to the mass of the reacting substances (reactants).
pen
if you burn a pound of pellets and captured all smoke do you still get a pound of ash and whatever
This gets complicated but I will give it a whirl. Technically, when you burn the pellets, all of the remaining ash, coupled with the mass of the emissions, will be greater than one pound. Here is why.
The chemical equasion for combustion is as follows:
matter + heat energy + O2= CO2 + H20
Essentially, matter and heat and oxygen will yeild Carbon dioxide and water, which accounts for all of the organic matter that is burned. The wood fiber in the pellets is essentially made up of carbon, hydrogen and oxygen and after combustion, what remains is all of the inorganic matter, such as iron, magnesium and sulfer. But, all of the inorganic matter remains in the form of ash. (although some inorganic matter escapes in fine particles as smoke)
When you mass out all of the ash and add it to the mass of the emissions, it will be greater than the one pound of pellets because through combustion, you have also added 02 to the one pound of pellets. This is not as a result of the law of conservation of matter, as this law only dictates that matter can neither be created nor destroyed.
I'm so confused
Matter is not created or destroyed in ordinary chemical processes.
You burn something, you simply turn it into something new by rearranging the atoms. The new substance has less energy that the original substance which is why your home gets heated.
what a conversation i agree with pen though otherwise the earth would be a different weight after billions of years of some sorta burning
Actually, the Earth IS a different weight. (technically, it is a different mass)
Anytime we launch a satelite or build a space station or send a rocket up into space, we leave matter behind. The mass of the earth decreases every time we leave something from Earth in outer space.
chit thats right you got me there
Yea but we also gain mass from all the space debris (such as meteor or meteorites) that get sucked into earth's gravity.
and it's added to as well. meteorite (and micrometeorites) and other matter and particles are constantly incoming.
DOH! didn't see pen's reply.
this is where it all started
  • [Hearth.com] theoretical question
ok. forgive me. it's very cool that you have done this.
it's just that the first thing i think seeing that particular photo, is the Red Green show. : P
lol. could be the umbrella.
it sounds like you are getting great efficiency, from what you mentioned.
good show haven't seen in awhile
