I've been designing my boiler system for my new home but am getting stuck on the thermal storage. My question is this; can I use a tank(s) without a heat exchanger by basically running these tanks in-line with the rest of the system allowing the boiler to heat the water directly instead of passively through copper coils? I don't see a problem with this and it seems to be much simpler design but I've seen most people using heat exchangers in tanks. I have access to all the 330 gallon IBC totes I want so I was planning on spray foaming 2 or 3 of them and running them in series (in the bottom, out the top) and in-line with my system. The totes are HDPE and inside steel cages and rated for 230 degree F constant temps. I guess I am hoping to hear that this will work the same as running coils through a tank but the only difference is having a much higher volume in the system. I think this would work great but I want to consult the experts here.
