Thermostat with larger swing
4Dtvman
63
East Bay of Rhode Island
I have a manual Lux unit right now and it works good but it seems that the stove turn off and 5 min later it starts back up. Is there a thermostat with a larger swing maybe 3 degree or so.
Thanks for any advice.
Skytechs are 3° both ways, which means 6° total.
Or a Lux does 2.25°… I think it does both.ways?? Not sure though. But that would be 4.5°…
The programmable Lux units like my TX500 can go up to 9 on the swing adjustment, I think. I have mine set at 2.
Maybe Jay T. can chime in....I think he has one like mine.
EDIT: I just checked....I have mine on 6.....pretty sure it goes to 9.
This is the one I have....swing settings from 1-9
http://www.luxproducts.com/thermostats/tx500e.php
My Lux LTX-1500u from Lowe's also goes from 1-9 each step is 0.25 Deg F each way so Dexter you are correct. 4.5 Deg F total swing. I like this T-Stat because the # 2 dip switch on the board changes it from 5-1-1 programmable to full manual operation!
http://www.lowes.com/pd_24971-37422-LTX1500U-006_0__?productId=3382134&Ntt=lux thermostat&pl=1&currentURL=?Ntt=lux+thermostat&facetInfo=
This T-Stat keeps the shed/workshop cozy connected to the Quadrafire Santa Fe with a toggle switch to turn it on from the house. :)
Click on pic to Enlarge
  • Thermostat with larger swing
Thanks for the info Don... ;)
Hope you had a good Turkey Day :)
I installed the
Lux 5-1-1 Day Programmable Thermostat
And it has a 2.25 swing up and a 2.25 swing down. So I'm happy. But after removing my old manual Lux I found the adjustment in side also for a 2.5 degree swing in side.......bummer. Well the new one is programmable
Hello
Yes, it is a nice one. The back lit #s are good too.
